Samsung washing machine WF1114XBD
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung washing machine WF1114XBD
  • #91569
    leighhibon
    Hi, does anyone have any experience with the 3E fault codes on these machines. I have checked the connections at the motor and also the module, they all seem ok. Does anyone know if a hall sensor is fitted on these, the same as L.G? Any help much appreciated. Thanks Leigh
    #448590
    Re: Samsung washing machine WF1114XBD
    Tech questions should be posted in the Trade Tech forum :lesson:
    Using the SEARCH facility 😉 I found a number of posts including this…..
    3E
    Motor Defect – Open / Short Circuit Windings, Loose Connector, PCB Fault
    Check – Armature ~2? Windings ~1.5?, Tacho ~40? Protector 0?
    #448591
    funkyboogy
    most likely pcb common issue,
    but if your unlucky its pcb and motor job
    motor has 10y warranty im sure probably best get customer to call samsung as they may fit the 2 parts
    ally
    #448592
    leighhibon
    Thank you very much.
