I’ve researched this fault which indicates a Hall senser error BUT this machine doesn’t have one or a direct drive system, its just got the inverter motor and large pcb at the top.
The 3 connections on the motor have a reading of 5.6ohms so I’m assuming there’s a problem with the pcb, as the 3 wires go directly to the pcb.
