Samsung washing machine WF80F5E5U4X
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Samsung washing machine WF80F5E5U4X
  • #96135
    andyjawa
    Hi everyone. Problem with this Samsung. Sometimes this machine if set, for example, Baby wash at 40 degrees at 1200 spin with 3 rinses =1hour 45 minutes. The machine will fill which is a pulsed fill and the drum goes around but sometimes within say 7 to 8 minutes at 1 hour 39 minutes the drum jerks ( as though it is stuck but isn`t ) and stops and will be like that for MOST of the remaining time to the end. The time remaining will not count down or if it does this programme takes 4 hours to complete! Other times the machine will work just fine as it should. Anyone had experience of this? The motor is a belt driven inverter type. Have megged the heater and that is fine ( it heats the water and is not to earth ) The motor wires seem ok, the valves ok, the p/swt hose is ok. Main pcb perhaps??
    #462451
    murv
    Have just done one, was the main pcb
    #462452
    andyjawa
    Thanks very much for your reply Murv. As expected the pcb.
    #462453
    andyjawa
    And yes it was the pcb. Many thx
    #462454
    punkaj000000
    Blocked
    #462455
    andyjawa
    Thanks everyone. Has been awhile now and has never gone wrong since so it proves it was the pcb jerking around.
