The customer reported a 3C error.
When I tested the w/m the circulating pump isn’t running. Its humming.
Could this cause a 3C error?
Also Connect and Qualtex show a single pump SAMDC3100181A .
Are the drain pump and circulating pump the same?
And is the pump wattage important?
Yes think both pumps are the same, but 3C is a motor error.
Can be brushes, but they’re also known for wires breaking on the motor harness, plus the boards fail.
Samsung is overpriced crap.
