samsung WD8704 pump problem
  • #88773
    got a Samsung
    WD8704RJA / XEU03
    y05754ab200429j
    Set machine on a spin only cycle
    pump try’s to start but does not. if you leave it running pump gives a flicker every now and then.
    have checked pump for wear and given it a push with a screwdriver but its evident there is no power getting to the unit
    I am assuming power board but having experience of the hot point problem with the TD ntc causing the same fault thought I would see if anyone else had any experience of this
    wilf
    Re: samsung WD8704 pump problem
    have you tried putting water into the drum to reset pressure switch ?
    wilf
    #439337
    no is there a procedure for that ?
    would not have thought it would have been relevant on the spin programme but then electronic machines can be silly.
    anyone got any tech info ?
    dave
    #439338
    Lawrence
    Thats a weird one Dave ,check the loom feeding the pump hint chafed ,and I have known poor crimp terminals,I assume you’ve got 240 at the pump ? they are just a normal askoll pump so nothing clever,otherwise yeah its the board and you need the part number off the board itself
    #439339
    thanks maybe worth a revisit to check the leads because board not too cheap
    WhiteVanMan1
    I’m sure you will be aware, but just in case, I went to one of these, not sure if it was the same model, but there is a switch on the filter door. Steve.
    #439341
    thanks for your input
    went out to panasonic like that but no switch on this one
    went out again today checked all connections and put a volt meter on leads
    its a board fault so customer is going to replace is as connect want £130 + vat +carr for the board
