Samsung WD90J6410AW/EU won’t fill on certain programs
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung WD90J6410AW/EU won’t fill on certain programs
  • #102248
    ali_g12
    WD90J6410AW/EU won’t fill on anything apart from 15 minute quick wash and rinse/spin. Don’t know these very well so went over the entire machine methodically with DVM and megger. No faults found. Probably missed out a couple of components. Wasn’t able to get into diagnostic mode as buttons 3 & 4 on resulted in spinny symbol for a couple of seconds followed by :-.
    Had to leave it as my ears were ringing from the ‘Samsung song’ playing for the hundredth time.
    Any ideas?
    #488071
    suedehead1
    assume you checked solenoids on water valve?
    #488072
    ali_g12
    suedehead1 wrote:assume you checked solenoids on water valve?
    This may have been where I made an assumption…………..the machine would run on the quick wash setting so I assumed the primary fill solenoid was working OK. Unless it uses an alternative solenoid to the usual fill!
