Samsung WF431ABP
  • #88963
    rocker
    when this machine is filling water is escaping from the soap draw, I have taken the dispenser & drawer out, can’t find any faults, checked the hose to tub, no blockage.
    I even turned the water pressure down, still the same.
    need to know if this is a known problem, bit worried about buying fitting new parts as I don’t know exact cause. John
    #439909
    Lawrence
    Re: Samsung WF431ABP
    is it “Glugging” and coming down the front or seeping around the edges of where the disp top seals to the bottom
    if it Glugs change the disp to tub hose as its not venting itself as it fills
    if its seeping then take the 2 sections apart and seal with Debor
    #439910
    rocker
    Hi Lawrence, thanks for reply, It is seeping but I believe its because when drawer is closed its sleeping from the closed joint between the drawer facia & base of dispenser not sealing ! but of course can’t prove that as unable to get visual look. John
