Samsung WF80F5E0W4W EU No motor action
Home Forums Trade Technical & Spare Parts Forums Samsung WF80F5E0W4W EU No motor action
  • #96767
    delta01
    only 4 years old ,carbon brushes fine , tried it on spin starts at 14 mins pumps out gets to 12 mins no motor action and fault code f6 any help appreciated thanks john
    #464760
    assume you have checked motor for continuity and checked harness back to board
    delta01
    Hi dave i dont have any circuit diagrams for this machine however i checked the connections at the motor and pcb ends then tried it again and it works, i then tried moving the cable to the motor whilst running to detect any broken wires but it kept running so i am not sure what the problem was , i will test it a few more washes hopefully it will be ok thanks john
    #464762
    Specialist01269
    Hopefully just bad connections, possibly at the PCB end. A fine fiberglass pencil works wonders for cleaning oxidation from the contacts.
