Starts and locks door but then goes back to start again (as if paused). When on test it worked ok several times but then went back to doing the same again, ie Fills and stops then goes back to the start time and stops as if on pause but without the light flashing.
Heater, motor, valves and pump all test ok so i suspect PCB or pressure sensor.
Any ideas welcome
