Samsung WF80F5E2W4XEU Washing Machine Drum Action
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung WF80F5E2W4XEU Washing Machine Drum Action
  • #98197
    jontymox
    Good morning all,
    I’m trying to diagnose a fault on the above w/m.
    Essentially, there is no drum action and I’m struggling to put my finger on the cause.
    The motor carbon brushes are fine, and I get Ohms reading on most of the nine motor terminals, (which I realise isn’t a conclusive motor test) and wonder if someone has a wiring diagram so I can check the motor fully?
    Having checked the motor multi plug, and re-fitted it, the machine decided to spin on a spin cycle for around five minutes, before resorting to the start of the twelve minute cycle, and no spin.
    A wiring diagram would be very useful.
    Many thanks,
    jonty
    #471330
    jontymox
    p.s. it would great if I knew what values should be expected between each motor terminal…
    #471331
    jontymox
    pps I gather there is a diagnostic mode, and wonder what the sequence is for this model and whether it will help?
    #471332
    Houseproudtim
    I’ve got one with the same problem, I’m guessing it’s the pcb, not sure whether to risk ordering one.
    #471333
    suedehead1
    I have had a couple with broken wires in the [lug going to the motor normally give them a pull and they break
