I have a problem with the e3 error I took the covers off and checked all connections . I managed to get into some sort of tech mode by pressing rinse spin and power button all together and had the machine going through various cycles without any problems so then refitted access panel and put washer back into place and am now getting the e3 error again
I have had another check of wiring and everything working fine until I load the machine to put through cycle it is ok until the washing is wet then e3 error again, is there some sort of pressure sensor for the drum that could be putting it into the e3 error
