samsung wf8702rsd fault code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries samsung wf8702rsd fault code
  • #76623
    QUICK FIX
    fault code tE2 is appearing im i right to think thermistor lgs flash up te
    #399283
    chezza
    Re: samsung wf8702rsd fault code
    duct assy fan housing sensor defective. should be ~12.8 k ohm at room temp
    #399284
    QUICK FIX
    dont suppose you have a part number
    #399285
    chezza
    not to hand, sorry. if no one else has it, i will post it up tomorrow evening for you
    #399286
    QUICK FIX
    ok that would be great
    #399287
    Lawrence
    probably a broken wire on the fan duct toc block,had one last week
    #399288
    QUICK FIX
    thanks lawrence thats what it was cheers
    #399289
    Lawrence
    :tup:
