samsung wf8702rss washing machine
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries samsung wf8702rss washing machine
  • #78055
    suedehead1
    hi i called out to look at the above washing machine,
    when its switched on all yhe lights on the pcb come on but it wont switch on, suspect pcb but was hoping someone might have had the same problem before any advice welcomed.
    #404311
    funkyboogy
    Re: samsung wf8702rss washing machine
    did you check door lock , these can be iffy on samsung
    havent seen many with this fault – but it could be pcb ?
    its one of those faults where you need to fit part to check
    ally
    #404312
    suedehead1
    Thanks I will try a door lock first
    #404313
    suedehead1
    fitted new pcb worked ok.
