samsung wf8702rsw/xeu tE2 error
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries samsung wf8702rsw/xeu tE2 error
  • #78425
    DDA
    I have a samsung air refresh washer that is showing the te2 error.
    i have replaced both the thermistors and still the error shows.
    Can anyone shed any light on this before i get the loom or the pcb.
    many thanks
    #405619
    Savbeowulf
    Re: samsung wf8702rsw/xeu tE2 error
    If definately seems like a temp sensor error so apart from checking for corroded connections or breaks in the loom I’m not sure what else to suggest
    Sent from my GT-N7100 using Tapatalk
    #405620
    Lawrence
    It’s a break in the loom ,pull your wires that go to the sensor and you should find ,butt connect the break and you are away
    #405621
    DDA
    thanks for the conformation.
    I think ill bypass the majority of the loom as it is fully, tightly bound with tape, also seems to be an intermittent fault so chances are it wont show when i get my meter our.
    dose the te2 error relate to both wash and air refresh ntc or just one of them, just to make it quicker in future?
    thanks
