Samsung WF8804RP tE2 Error
  • #68812
    pwalo
    Hi All,
    I’ve been repairing the above washer because of a tE2 error.
    The error used to come on 10 minutes into the wash and I’ve replaced the thermistor and checked the wiring to the PCB.
    All then seemed well but close to the end of the cycle (spin) the error reappeared. Heater tests fine. Everything else seems to work fine.
    Any suggestions?
    #372836
    pwalo
    Re: Samsung WF8804RP tE2 Error – FIXED
    Just in case anyone comes across this problem.
    Eventually found it to be an intermittent broken wire that goes to the second thermistor on the Air Refresh duct on top of the drum.
    It was broken where the wiring loom comes off at 90 degrees and heads to the thermistor. Samsung had made the bend too tight and it eventually failed.
