Samsung WF90F5E5U4W/EU motor sticks
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung WF90F5E5U4W/EU motor sticks
  • #93475
    chitts
    My customer has this Samsung w/m that has a fault where the motor grates when on wash and sometimes shudders and sticks. The drum is free to turn and no bearing wear.
    I don’t see many of these and have not seen this before. I think it’s a motor fault but would like advice from anyone who may have seen this before.
    #454458
    Re: Samsung WF90F5E5U4W/EU motor sticks
    sounds like its a 3 phase motor that’s lost a phase
    if that’s the case can be either motor or control board
    no access to tech on this is it direct drive or separate motor and belt ?
    murv
    Most likely a power module fault. Check the motor windings read the same value across any 2 of the 3 terminals (ie top to middle, bottom to middle, and top to bottom)
    #454460
    DWSERV
    Confirmed fitted Power Module DC9201223C problem solved
