Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Samsung wm
- This topic has 12 replies, 6 voices, and was last updated 16 years, 2 months ago by
franz.
January 13, 2010 at 5:15 pm #51602
franz
ParticipantI have 2 samsung wm’s with the same fault
1 x J1453s and 1 x P1453.
Both will not spin but just get to 9 mins on display then go back to 10 mins and then alternate between 10 and 9 mins – pumping out o.k. -motor gets to distribution speed – brushes appear o.k. – about an inch left – heater meggers o.k. – any ideas guys?
FranzJanuary 13, 2010 at 5:55 pm #308704Dales-Electronic
ModeratorRe: Samsung wm
PCB every time
January 13, 2010 at 7:38 pm #308705franz
ParticipantRe: Samsung wm
FranzJanuary 19, 2010 at 4:21 pm #308706franz
Have tried new pcb in the j1453 – stil sticks at spin cycle – just reaches distribution speed but will not spin and display gets to 9 mins then goes back to 10mins and repeats this forever – any ideas guys
FranzJanuary 19, 2010 at 4:26 pm #308707robbra
Normally means the machine thinks it hasn’t emptied. Have you checked the pressure pot and switch?
RobJanuary 19, 2010 at 4:46 pm #308708franz
will try that – thanks robbra
January 29, 2010 at 7:43 am #308709pmb
Hi Franz have you managed to solve these? i have the same problem on a B1445sgsx which i have replaced the pcb, checked for blockages in pressure chamber and made sure there is a good load in there. Is the load sensor part of the pcb or is it separate?
Thanks Peter :lesson:January 29, 2010 at 8:11 am #308710franz
Hi Peter – sorry mate , I tried new pcb & pressure switch – no joy.
FranzJanuary 29, 2010 at 8:39 am #308711lee8
Are you running tub empty or with load, could be out of balance detection.
If empty still no spin I’d try a motor.
January 29, 2010 at 5:17 pm #308712pmb
Thanks for getting back to me guys 🙂 i ran it without a load and it went into spin fine but when i ran it with a normal load it kept trying to balance it, does anyone know how the load sensors work on these? sorry to hijack your thread Franz
January 30, 2010 at 9:03 am #308713robbra
Could be one of those stretchy belt gone a bit loose as any jerky rotation on the distribute would stop it spinning with a load. Servis suffered greatly with this problem. Check the tension.
RobJanuary 30, 2010 at 10:14 am #308714admin
KeymasterRe: Samsung wm
I’ve had same with some servis & whirlpool machines,put new belt on or tighten up belt , then she spins again!
CanufixitFebruary 1, 2010 at 8:09 am #308715pmb
Thanks alot guys i will get a new belt for it thats great 😀
