I have a problem with a Samsung WW10N645RPW/EU, when you press the start button, the door locks then after a short period the door unlocks, tried it on a spin only function at it does the same, any ideas has to what the problem could be ?.
I have had this one before. It was the actual door lock fooling around but as a caveat it might not be on your machine. You buy the part at your own risk.Part number is genuine samsung part number is DC3400026A or the so called pattern part ( which is really the genuine repackaged as far as one can tell! ) is Qualtex part number QUAINT116OQ.
