Home › Forums › Trade Technical & Spare Parts Forums › Samsung WW10T534DAN/S1
- This topic has 7 replies, 2 voices, and was last updated 1 year ago by
chuffy.
March 10, 2025 at 2:55 pm #103247
chuffy
ParticipantHi I have a strange fault on this washing machine.
When you switch on it’s locked in the previous programme but it does nothing.
Doesn’t even lock the door.
Unable to cancel or reset.
Managed to get it into a “demo mode” which it skips through very,very quickly and sometimes the led display goes very dim or disappears completely!
I suspect either the user interface module or the power module is at fault.
Both are quite expensive items so I’m a bit reluctant to get involved.
Anyone else had this issue and is there a way to run a diagnostics programme on the machine?Cheers
March 10, 2025 at 6:39 pm #492333electrofix
Moderatorhave you checked the child lock is off ?
March 10, 2025 at 10:54 pm #492334chuffy
ParticipantHi Dave.
Yes checked that.
Couldn’t activate or deactivate because screen locked.
By holding temp and spin buttons it goes into demo mode which only takes about 30 seconds then says complete.
Like I’ve previously said sometimes the led display goes off completely or goes very dim.
On one occasion whilst investigating I could get it to spin and pump out but the reverts to the locked programme and screen goes blank/dim.March 10, 2025 at 11:59 pm #492335electrofix
Moderatorwell as a long shot you can disconnect as much as you can and see what happens but I think you have a board problem. not unusual on Samsung
the problem is which board
touch display board is £88 on Aswo
2nd board down below at £95 on Aswo
all plus V and p&p
DaveMarch 11, 2025 at 11:43 am #492336chuffy
ParticipantUser interface pcb £75 plus the usual on Connect site.
Dont know if it’s worth a shot or not?March 11, 2025 at 9:08 pm #492337electrofix
Moderatorwell connect are showing me £91
connect pt no 5055005000178
got the part no for the part from aswo. should be DC92-02642N but you would need to double check
as you say it may not be worth it
March 12, 2025 at 9:43 am #492338chuffy
ParticipantJust realised that you quoted the vat inclusive price!
March 12, 2025 at 9:47 am #492339electrofix
Moderatorcant see that its too small but assuming its the same part no I stated above
does not suprise me, dont use connect much but if they charge me more its not suprising
its mad a company wants my business but is always dearer than my other supplier and expect me to use them
