This is a twin motor twin pulley machine. 1 inner pulley works via a belt the drum and the outer pulley via another belt drives the drum`s internal impellor. What the problem is is that the impellor pulley is faulty and its shaft which goes through the bearing main shaft is loose as though its own bearings are shot. The actual drum bearings are fine. Has anyone got any info as to whether I would need just the metal impellor, its bearings and its pulley or a complete rear half plastic tank or what else. I cannot find any info on this machine that points me in the right direction. Never seen this machine before.
Any help very welcome.
