Samsung WW90M645OPX/EU
  • #102896
    WhiteVanMan1
    The machine is throwin up error code dC.
    The only thing I can find this refers to is an unbalanced load? It’s there from switch on. I did suspect’t door interlock n’ it worked once after I replaced it, then it showed’t error code again. Any ideas please? Steve.
    #490949
    matrixresonator
    Door lock error. Also check wiring on motor they can get damaged and cause weird things to happen
    #490950
    WhiteVanMan1
    Thank you for that. I’ll check it out. Steve.
