Samung WD90J6410AW/EU Washer/Dryer cuts out afte 15 minutes drying
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samung WD90J6410AW/EU Washer/Dryer cuts out afte 15 minutes drying
  • #95241
    Twoten
    I have looked at the above 3 year old Samsung washer/Dryer that cuts out after 15 minutes of drying.
    I found the overheat thermostat had tripped therefore no heat. I reset the thermostat and tested. I found the condenser a bit blocked so cleared it.
    The inlet valves are letting water through to cool the condenser, the fan motor runs OK.
    The customer used the dryer twice without any problem but it appears to have gone again.
    Can anyone tell me what resistance I should expect from the dryer NTC?
    Other than the NTC is there anything else I may have missed on this?
    Thanks.
    #459769
    neon_3SP_glow
    Not familiar with the model, but have had similar problems on other machines IF they have a wire mesh filter – where the drying chamber attatches to the tub.
    gets clogged and reduces airflow.
    #459770
    Twoten
    neon_3SP_glow wrote:Not familiar with the model, but have had similar problems on other machines IF they have a wire mesh filter – where the drying chamber attatches to the tub.
    Thanks neon_3SP_ glow I removed the condenser to clean and checked in the connector to the tub but there wasn’t a mesh on this one.
    The resistance of the dryer NTC measued 51kΩ at room temperature and 11.88kΩ following dryer cool down after cancelling the dry cycle when it was still quite warm.
    I’m struggling to find any other information on this machine that helps.
