Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › sandwhich chiller
- This topic has 7 replies, 5 voices, and was last updated 17 years ago by
andysam.
March 16, 2009 at 2:37 pm #44272
andysam
Participantiv just been to a glass fronted sandwhich chiller. it got regassed by someone else. the problem is the compressor is now very noisy. ive checked the refrigerant levels and there ok. is there a chance that it hasnt got enough oil in the compressor? can anyone help.
March 16, 2009 at 5:08 pm #280421maltheviking
ParticipantRe: sandwhich chiller
andysam wrote:iv just been to a glass fronted sandwhich chiller. it got regassed by someone else. the problem is the compressor is now very noisy. ive checked the refrigerant levels and there ok. is there a chance that it hasnt got enough oil in the compressor? can anyone help.
Cant see how it’s lost oil, even if it had a gas leak previously,probaly just a noisy or nackered comp. 😯
March 16, 2009 at 5:09 pm #280422maltheviking
March 16, 2009 at 5:11 pm #280423maltheviking
Wow a bouble post, long time since I managed that P45 :rolls: :rotl:
March 16, 2009 at 6:18 pm #280424Penguin45
:p45:
March 16, 2009 at 7:05 pm #280425spimps
What’s
the compressor no and back pressure.
Presume it’s on 134a
Could be non condenseables causing the problem,you can’t be sure of what else (air/moisture etc) went in along with the refrigerant when rechraged sounds like you would have to take out the current refrigerant,pull a fresh vacuum so you know the system is ok and then recharge with refrigerant as marked on the plate.March 16, 2009 at 7:15 pm #280426PINKY
Assuming they put in the right refrigerant? :rolls:
March 17, 2009 at 10:20 am #280427andysam
cheers fellas i will try get out all refrigerant and put on a long vac hope it dsnt need a new comp just seen the price for a replacement wot a joke for a bit of metal.
