Sanyo Combi Microwave EM-D9553SN
Home Forums Public Support Forums Help And Support Other Appliances Sanyo Combi Microwave EM-D9553SN
Viewing 15 posts - 1 through 15 (of 20 total)
  • #103095
    clicon357
    Morning,
    We’ve a “much loved” Sanyo Combi Microwave, EM-D9553SN here, the second Sanyo tbh and it’s given years of great service. Oven and grill still work but I think the magnetron has packed up. It was working last night then made a single noise like if something metal was in there (there wasn’t). Thereafter the microwave section isn’t working. I’ve had the top cover off and noticed a burn mark on the connector. SWMBO only mentioned last night that “it’s been sparking for a couple of weeks”. The waveguide appears intact and undamaged from a quick look.
    https://flic.kr/p/2qwBSWh
    The magnetron is a Toshiba part 2M253H (IF).
    https://flic.kr/p/2qwAjqp
    I can find plenty of new 2M253H ones but not with the (IF) suffix. Is there something else that will fit?
    Appreciate it’s an old model but it seems a shame to scrap it. Plus my daughter is autistic and used to it. Not the worst case if I have to get a new one (microwave not daughter).
    Thanks for looking.
    (apologies for the Flickr photo links, I tried uploading attachments but got a message that said “You have exceeded your usergroup’s upload quota of 19.5kb by 2.62MB“)
    #491763
    that could well be just a bad connection
    Do you realise you are dealing with 5000 Volt DC and in fault conditions there is enough stored energy to kill you after you have unplugged it
    do you know the safety proceedures to follow to keep safe ?
    clicon357
    [USER=”4209″]electrofix[/USER] many thanks for that.
    Yes well aware of the potentially lethal voltages inside thanks. The day job involves safe isolation etc.
    As I understand it, from some further reading since I posted, the (IF) suffix on the Magnetron dictates the mounting. I’ll remake that crimp as a first port of call. I wonder if another 2M253H could be got, taken apart and utilise the (IF) mounting from the original?
    #491765
    you will be able to get a mag. can point you at that one
    first do the joint
    magnetrons have 2 power sources , a high voltage on the anode to earth and a low voltage high current for the heater. if the joints fail the heater wont be hot enough to work. had that fault loads. found it best to crimp and solder the joint as its often solid wire
    clicon357
    A little bit of investigating just now. All measurements with leads removed:
    The capacitor measures nom 1uF
    Across the magnetron I’m seeing nom 0.3 ohms.
    Though the clear insulating boot on the red lead to the magnetron appears scorched, the actual connection doesn’t show any sign of overheating. Still a potential high resistance joint? I could solder it.
    https://flic.kr/p/2qwFzJ3
    I have found though the 750mA fuse has blown!
    https://flic.kr/p/2qwFm4w
    #491767
    clicon357
    This big diode appears open circuit!
    https://flic.kr/p/2qwFBXL
    So I’ve found the duff fuse and diode any suggestions as to the cause?
    #491768
    clicon357
    Slight correction…
    I read that a standard multimeter might not have enough forward voltage to check these diodes. Went and found a good 9V battery and like this got apparent continuity one way:
    https://flic.kr/p/2qwGAUN
    #491769
    well you wont know till you replace fuse
    if the manetron is arcing internally you wont know till its powered up with a new fuse
    Diode will be fine. if they go its normally short circuit
    caps can go short too but you getting a good reading on it
    you have only measured the heater on the magnetron but now set multimeter on the highest ohm scale. one lead on either of the mags terminals and the other one on the metal casing. you should get no reading at all. if you get any mag is scrap
    clicon357
    “you have only measured the heater on the magnetron but now set multimeter on the highest ohm scale. one lead on either of the mags terminals and the other one on the metal casing. you should get no reading at all. if you get any mag is scrap”
    Forgot to say I did that too, with the meter set on the 2K resistance range. No reading from either terminal to the metal casing of the mag.
    #491771
    prob ok but do it on a meg ohms scale before you go further
    clicon357
    electrofix wrote: prob ok but do it on a meg ohms scale before you go further
    Thanks. As in “megger it” with an insulation resistance meter? Mine is an old 500V job.
    #491773
    that will be perfect
    clicon357
    OK, a bit of early morning meggering: I measured infinity between the magnetron casing and either terminal:
    https://flic.kr/p/2qwMMVu
    As aforementioned, across the same two magnetron terminals on the low resistance range I’m seeing nom 0.3 ohms.
    #491775
    clicon357
    I’ll order some fuses this morning. Noticed they’re damn tight in the end caps!
    #491776
    some fuses are fixed in the end caps and you have to get the complete fitting
