Home › Forums › Public Support Forums › Help And Support › Other Appliances › Sanyo Combi Microwave EM-D9553SN
- This topic has 19 replies, 2 voices, and was last updated 1 year, 4 months ago by
clicon357.
November 27, 2024 at 8:07 am #103095
clicon357
ParticipantMorning,
We’ve a “much loved” Sanyo Combi Microwave, EM-D9553SN here, the second Sanyo tbh and it’s given years of great service. Oven and grill still work but I think the magnetron has packed up. It was working last night then made a single noise like if something metal was in there (there wasn’t). Thereafter the microwave section isn’t working. I’ve had the top cover off and noticed a burn mark on the connector. SWMBO only mentioned last night that “it’s been sparking for a couple of weeks”. The waveguide appears intact and undamaged from a quick look.
The magnetron is a Toshiba part 2M253H (IF).
I can find plenty of new 2M253H ones but not with the (IF) suffix. Is there something else that will fit?
Appreciate it’s an old model but it seems a shame to scrap it. Plus my daughter is autistic and used to it. Not the worst case if I have to get a new one (microwave not daughter).
Thanks for looking.
(apologies for the Flickr photo links, I tried uploading attachments but got a message that said “You have exceeded your usergroup’s upload quota of 19.5kb by 2.62MB“)
November 27, 2024 at 10:16 am #491763electrofix
Moderatorthat could well be just a bad connection
Do you realise you are dealing with 5000 Volt DC and in fault conditions there is enough stored energy to kill you after you have unplugged it
do you know the safety proceedures to follow to keep safe ?
November 27, 2024 at 12:35 pm #491764clicon357
Participant[USER=”4209″]electrofix[/USER] many thanks for that.
Yes well aware of the potentially lethal voltages inside thanks. The day job involves safe isolation etc.
As I understand it, from some further reading since I posted, the (IF) suffix on the Magnetron dictates the mounting. I’ll remake that crimp as a first port of call. I wonder if another 2M253H could be got, taken apart and utilise the (IF) mounting from the original?
November 27, 2024 at 12:56 pm #491765electrofix
Moderatoryou will be able to get a mag. can point you at that one
first do the joint
magnetrons have 2 power sources , a high voltage on the anode to earth and a low voltage high current for the heater. if the joints fail the heater wont be hot enough to work. had that fault loads. found it best to crimp and solder the joint as its often solid wire
November 27, 2024 at 4:19 pm #491766clicon357
ParticipantA little bit of investigating just now. All measurements with leads removed:
The capacitor measures nom 1uF
Across the magnetron I’m seeing nom 0.3 ohms.
Though the clear insulating boot on the red lead to the magnetron appears scorched, the actual connection doesn’t show any sign of overheating. Still a potential high resistance joint? I could solder it.
I have found though the 750mA fuse has blown!
November 27, 2024 at 4:43 pm #491767clicon357
ParticipantThis big diode appears open circuit!
So I’ve found the duff fuse and diode any suggestions as to the cause?
November 27, 2024 at 6:15 pm #491768clicon357
ParticipantSlight correction…
I read that a standard multimeter might not have enough forward voltage to check these diodes. Went and found a good 9V battery and like this got apparent continuity one way:
November 27, 2024 at 8:42 pm #491769electrofix
Moderatorwell you wont know till you replace fuse
if the manetron is arcing internally you wont know till its powered up with a new fuse
Diode will be fine. if they go its normally short circuit
caps can go short too but you getting a good reading on it
you have only measured the heater on the magnetron but now set multimeter on the highest ohm scale. one lead on either of the mags terminals and the other one on the metal casing. you should get no reading at all. if you get any mag is scrap
November 27, 2024 at 9:31 pm #491770clicon357
Participant“you have only measured the heater on the magnetron but now set multimeter on the highest ohm scale. one lead on either of the mags terminals and the other one on the metal casing. you should get no reading at all. if you get any mag is scrap”
Forgot to say I did that too, with the meter set on the 2K resistance range. No reading from either terminal to the metal casing of the mag.
November 27, 2024 at 9:37 pm #491771electrofix
Moderatorprob ok but do it on a meg ohms scale before you go further
November 27, 2024 at 9:47 pm #491772clicon357
Participantelectrofix wrote: prob ok but do it on a meg ohms scale before you go further
Thanks. As in “megger it” with an insulation resistance meter? Mine is an old 500V job.
November 27, 2024 at 9:51 pm #491773electrofix
Moderatorthat will be perfect
November 28, 2024 at 6:25 am #491774clicon357
ParticipantOK, a bit of early morning meggering: I measured infinity between the magnetron casing and either terminal:
As aforementioned, across the same two magnetron terminals on the low resistance range I’m seeing nom 0.3 ohms.
November 28, 2024 at 6:26 am #491775clicon357
ParticipantI’ll order some fuses this morning. Noticed they’re damn tight in the end caps!
November 28, 2024 at 9:56 am #491776electrofix
Moderatorsome fuses are fixed in the end caps and you have to get the complete fitting
