I have a problem with a Sarena Professional 90 range cooker.
It appears that the main fan oven element has failed and I have already obtained a spare.
Question
Is the element replaced from within the oven housing
or
is it replaced via the back of the oven?
Re: Sarena professional 90 Range Cooker main oven element
you access it from the front internal oven cavity.Some though also need to be accessed through the rear panel also dependent if its got screws or nut fitment.
Bryan thanks, screws in both cases front and rear. At the back it would appear that the whole (large) rear panel would have to be removed.
In the oven cavity looks as though side panels might obstruct removal of the rear panel. Also the grill element (yes there is a large grill in the main oven) is fixed to the rear panel.
