Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Scandinova fridge help
- This topic has 6 replies, 4 voices, and was last updated 21 years, 4 months ago by
gmctyphoon.
December 5, 2004 at 9:51 pm #7021
gmctyphoon
ParticipantAnyone got any ideas for me to try befor I scrap this fridge.
Its a Scandinova LF6-86/S about 2 1/2 years old!
It has just stopped working overnight.
Power is on & getting to the light, but the motor doesnt seem to be activating.
Anybody also had happen? could this be the ThermostatI have had a quick check on the rear wiring for any loose connections etc (the basic stuff) but no joy.
Plaase help if you can.
Cheers
December 5, 2004 at 10:29 pm #120961Dave_Conway
ParticipantRe: Scandinova fridge help
Scandinova is a Comet brand name but may well be manufactured by one of the “better known brands”.
Can you have a look inside the fridge compartment, most likely next to the salad bin and post up all the numbers you can find from the rating label.
December 6, 2004 at 7:43 am #120962whitegoodsman
this product is made by vestfrost im sure one of the fridge guys on this site can help you
December 6, 2004 at 3:23 pm #120963gmctyphoon
All the nos on the side are..
Serial no 20011101067
Refrig R600a 0.032KG
0-S250-B24-B4920150
Cheers Guys.
December 6, 2004 at 3:35 pm #120964admin
KeymasterRe: Scandinova fridge help
The most common problem is thethermostat if its just the fridge not working,it will require the extra long capillary though.iIf its a drost free model then it may well be that the door hasnt been fully shut at some point in the past week or so,if it is frost free try to emty the appliance ond turn it off for 24hrs with the freezer door open and then restart it and see if it works ok.
bryan
December 8, 2004 at 9:21 pm #120965gmctyphoon
The thermostat has now been replaced & is working great, had a small hickup as the wiers to the new stat were around the wrong way at first & sent the fidge to -10 deg!!!!!!!! VERY COOL BEER!
All fine now.
Anyone else needs to acsess the stat, take off door with 2 top alen bolts, turn light shroud anti clockwise to remove, take 3 plugs from front top of fridge, need a deep alen key (5mm I think it was, same as door hanger).
This then pulls away to reviel stat & wiring.Cheers for your help.
January 6, 2005 at 10:54 pm #120966admin
Hi gmctyphoon,
Could you tell me where you got the thermostat for your unit?The fridge on my Scandinova frost free fridge freezer has stopped working – again. Last time it was the thermostat and I’m guessing that it’s gone again and I’d rather fit it myself than spend out on a repair guy.
FF6745D
BNKF332
0-5332.610-62010150
91704681Thanks
