Scandinova Fridge just not cooling Type LF 110C, R134a
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Scandinova Fridge just not cooling Type LF 110C, R134a
  • #24063
    sid47
    I have a freestanding Scandinova Fridge possitioned next to a freestanding Scandinova Freezer. They have been working fine for a good number of years. However for the last couple of weeks I notice that the temperture inside the fridge is just not low enough. The guage actually shows 8 degrees. It seems to me staying at room temperature.
    The panel inside the back of the fridge is pretty cool to touch and is misty.
    I desperately need some advice as to what may be the problem.
    #200514
    Fairdeal
    Re: Scandinova Fridge just not cooling Type LF 110C, R134a
    Can you hear the compressor running all the time?
    If so then it could be gas problem.
    As for the panel inside, at high thermostat setting, drops of ice should form. If the compressor is not running then it could be few other things.
    Regards
    #200515
    sid47
    I think I can hear the compressor running most of the time.
    The panel inside does have droplets of ice forming but you are able to wipe them off with your hands.
    If it is a Gas problem… what would the procedure be.. at least cost.
    #200516
    Fairdeal
    Re-gas has to be done by a professional because of the Refrigerant.You have to collect the gas and dispose off properly with the recovery machine.
    The charges for that particular job varies b/w £80 and £120.
    Best to have to inspected.
    Have a look in Find Repairs to see your nearest engineer.
    Regards
