I have 2 scandinova upright fridge freezers model no FF6745D and the problem is that 1 of the fridges has stopped working (although the freezer is OK) and also 1 or both has water coming from underneath (nearly broke my neck on the wet floor again today!). I understand from from your FAQ section that the water may be due to a blocked channel but am unsure where to look/clean out (the drain holes in the back of each fridge are clear). If I can sort the water leaking I don’t know if it’s going to be financially viable to get the fridge repaired.
how old is appliance
if old may be insulation on bottom of appliance has failed,
you will be able to tell just by pressing the bottom of appliance and it will be soft (very)
check drip tray on back of compresser has no hole in, some times get hot on crack
