Anyone know the part number for the small pressure switch on this machine. Presumably a flow guage for the heater circuit as its hose is connected at the bottom of the circ pump chamber.
That sounds something similar to a Whirlpool dishwaser p/switch.
It makes sure the water pressure is sufficient before allowing the heater to be switched on.
Anyway Tony, could you send me an email to remind me to check this on Monday for you, the only reason I ask is I have been away for 24 hours and the ammount of posts being put up recently, I may well miss/forget it.
