I stripped the oven down tonight and found the reason behind the always ajar oven door. The wheels that the door forks run against are totally clapped out. So that’s what that grinding noise was then when opening and closing the door……. The oven is a Scholtes Multifonction F 4805 ELX and I need two of the above wheel assemblies. These are screwed to either side of the front plate of the oven and have steel plates (heat deflectors?) riveted to them. Can anybody offer me any advice on where I can get these items and what the cost is likely to be? I would be grateful for any help.
These are the door hinge runners and are £4.46 each inc VAT, plus postage.
If you would like me to order them, please email me directly. Please check they are both identical as it only shows one on the diagram , they normally are though.
