Re: Schrach PB314012 relay required
You can try putting the part number straight into Google. However I tried it for your part and although data sheets and plenty of other stuff turn up I couldn’t find anywhere to buy it 😡 . Still, if you persist, and maybe go to the trouble of registering with tyco electronics you might get some help.
Alternatively go to radionics.ie and browse through the relays by tyco > schrack > 12v > and so on till you get down to something which has same specs or near enough (you may need to compare data sheets but the essential stuff should be printed on the relay itself). OR telephone them, give them your part number and they should be able to suggest a suitable alternative.
Mike.
