Schreiber APM 6121
  • #25580
    AndrewUK123
    I’ve got a Schreiber APM 6121 Fridge Freezer which I’ve had for 6 years now with no problem.
    However I’m finding that lately it’s been creating a lot of ice on the back wall of the fridge part and also finding that the door doesn’t always close propperly (easier to spot of a evening when you can see the lnterior light!)
    Are the two things linked ?
    The fridge is a fitted type and has a wooden door fascia, although I can’t see any obvious obstruction preventing to from closing propperly.
    What can I do to fix the ‘not always closing propperlu ‘ problem – is this in need of a new door ?
    Thanks In advance.
    Andrew
    #206478
    Dave_Conway
    Re: Schreiber APM 6121
    AndrewUK123 wrote:Are the two things linked ?
    Almost certainly 🙂
    One or both of the hinges has dropped/broken by the sound of it, check for cracks etc as these are a very common failure, see 246009700 and 246009800 in our on-line shop here:
    http://shop.ukwhitegoods.co.uk/hingekit … -hinge-kit
    #206479
    keelaw
    Hi there, I have similar symptoms as above but from my checking of the hinges, nothing seems to be completely broken or loose. I can “prop” the door up slightly by a small amount and this does help the door to close a bit better. Could it be that something has stretched a little? Should it be more obvious that something has “gone” with the hinge?
    By the way, what an excellent website. I have already ordered a new freezer door handle as I snapped this completely last night! Shame about these useless MFI fridge freezers!
