schreiber apm 6321 integrated fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum schreiber apm 6321 integrated fridge
  • #63135
    sab
    I suspect that the thermostat has gone faulty as where ever i set the control knob to the fridge stays at around 6-9degrees C although it does click on and off- or do you think it could be another fault
    if so is it fairly easy to fit new thermostat?and can you supply
    the serial no of fridge is 20000805777
    many thanks
    simon
    #352705
    Re: schreiber apm 6321 integrated fridge
    The thermostat for that fridge is here.
    But, in all honesty, it doesn’t sound like a stat problem. It sounds more like a ventilation and subsequent overheating problem or, the fan motor faulty giving the same sort of symptoms or a compressor failure.
    HTH
    sab
    thanks for reply i do not think it is over heating as there is plenty of room under the plinth and fridge has been there for about 10 years
    have cleaned up dust and fluff with vacuum
    fan seems to run fine as does the compressor
    still the same problem
    #352707
    If the compressor isn’t pumping as it should, it will create those symptoms.
    HAs it got a layer of frost approx. 5mm thick on the back wall ?
    If it has then the most common problem is that the evaporator plate has detached from the liner which makes the appliance un repairable.
    Bryan
    #352709
    sab
    no layer of frost on back wall at all
    thanks
    simon
    #352710
    sab
    thanks for replies
    if it is the compressor is it worth getting a replacement one -if available -or do i scrap the fridge and get a new one
    is there any way of testing the compressor?
    simon
    #352711
    sab
    problem solved
    i found an article on how to test thermostat
    basically bypass the thermo and see if compressor runs continuously which it did and temp went down to nearly zero
    fitted new thermo now working perfectly
