Need to replace a Schreiber apm6121 intergrated fridge. Does anyone know the size of this model or somewhere I can get information regarding this product.
Thanks Don but I have seen them with widths between 50 and 60cm which could cause a problem if it’s too wide. I have no access to the property so cannot measure the space available. Just know the model number and that there is an integrated freezer next to it.
I think you may be getting confused between column fridges these are usually in a tower housing freezer on the bottom and fridge on top and are 540 wide and 875 tall.
Under worktop or built under are 590 wide and 820 high and have height adjustable legs.
