Schreiber APM6855
  • #39721
    subs
    S/N 20061503324 This FF is icing up on evaporator causing warm fridge.
    I have tested everything on it and it all seems ok i.e heater, toc, derost sensor, temp sensor.Ive checked the small board behind the condensor and the main control board, neither have any visual signs of damage.What are the common faults with these (when everything checks out). Is it the boards or the defrost sensors. When i measured the evaporator sensor i got 18500 ohms when it was frozen. I did a search on this ff but although there is a few threads on this problem, there is no answers to them. Any help please.
    Subs
    #263344
    jd
    Re: Schreiber APM6855
    I have had this problem on a couple of occassions and changing the no frost sensor in the evaporator seems to cure the problem, it is a relatively cheap part around £15.00 available from connections sorry not sure of part number, hope this helps jd.
    #263345
    502023500 – version -0
    502055800 – version -1
    subs
    Thanks Guys! Ill give it a try.
    Subs
