schreiber apm6855
  • #47907
    robbo1973
    hi all been here today complaint of no cooling in fridge servis made f/frzr fan motor o/c changed and refit but did not run ,when you put meter into tags and shut door to activate reed switch there is only 76volts getting to fan motor.what could cause this has anyone got a wiring diagram? or had this fault all help appreciated.
    cheers chris
    #294972
    Simon46
    Re: schreiber apm6855
    Fan motor reads oc when i went to one.But it works. odd
    #294973
    robbo1973
    this fan was defo not running at all so changed but only 76 volts any ideas?
    #294974
    SAMURI
    Try bypassing the reed switch in the freezer as this is most most likely the fault.
    Make sure you have the unit unpluged from the mains as wires stay live or you can open the fridge door as this cuts of the power to the reed switch.
    If this is the problem you can leave it bypassed until you can order and obtain a replacement.
    #294975
    SAMURI
    ALSO CHECK THE MAGNET ON TOP OF THE FRIDGE DOOR IS STILL FITTED AS CUSTOMERS SOMETIMES REMOVE IT.
