Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Schreiber APP 6403 Failure
- This topic has 13 replies, 10 voices, and was last updated 19 years, 4 months ago by
KR.
November 24, 2006 at 8:12 pm #22847
KR
ParticipantI have Schreiber APP6403 integrated freezer which after defrosting will not re-start either by the thermostat or fast freeze. Can anyone advise what the problem is and its rectification
November 24, 2006 at 8:18 pm #196295kwatt
KeymasterAre you perchance getting a click-buzz from it?
November 24, 2006 at 11:29 pm #196296KR
ParticipantAll warning lights etc operate but there is nothing at all no click-buzz nothing at all
November 24, 2006 at 11:40 pm #196297Dave_Conway
ParticipantRe: Schreiber APP 6403 Failure
These electronically controlled models seem to be dropping like flies 🙁
The PCB is normally the culprit on this model, you can get one here:
http://shop.ukwhitegoods.co.uk/product_ … cts_id=687
Power off please when checking :zap:
November 25, 2006 at 12:03 am #196298KR
ParticipantThanks for the info, could there be any pitfalls when replacing
December 3, 2006 at 12:24 pm #196299bikemec
Our freeze has done the same thing, just defrosted, warning and light bleeper went off, no other noises, pump doesn’t start up etc..
How hard is it to change this circuit board ? and where abouts in the freezer can it be found?
thanks in advance
December 3, 2006 at 10:23 pm #196300KR
The pcb can be accessed by removing the plastic strip on the top panel to the rear of the door. The pcb was given to a local engineer to check last thurs and he advises that the pcb is being repaired and will be available mon. Will advise outcome
December 5, 2006 at 5:47 pm #196301bikemec
thanks for the replies, but my girlfriend found the paper work that came with the freezer, and discovered she’d taken out the extened waranty. including parts and labour until 2008…
so looks like no need for me to get my hand dirty, nice man is coming tomorrow…
thanks anyway
November 23, 2007 at 7:58 pm #196302ah
I’ve just received a new PCB from UK Whitegoods and fitted it in less than ten minutes.
First turn off the power supply!! Open the freezer door and turn the thermostat dial to 0 (furthest anti-clockwise). Then prise off the white thermostat/light panel with your fingers. Start at the right hand end and the thermostat dial peg should pop out. Gently prise the whole panel off and put it somewhere safe.
Unscrew any clamps or brackets securing the freezer to the underside of the worktop, and pull the freezer forward to expose a small plastic panel on the top surface. Prise this out. It’s held by two clips on its back edge. This will expose the old PCB. Simply lift this up out of its slot and disconnect the two electrical connections.
To fit the new PCB first check that it is set to the lowest temperature (furthest anti-clockwise). If not, use the dial peg you removed earlier to correct this. Connect the two sets of electrical wires to the PCB and slot it down into place. (Make sure the dial hole is to the right). Replace the plastic cover on the top, then the white plastic thermostat/light panel, making sure the dial peg is turned to its lowest setting before you insert it.
Push the freezer back into position and re-fix to the underside of the worktop.
Set the thermostat dial to between 2 and 3, turn on the power and press the fast freeze button on the left. Close the door and wait for the freezer to achieve the set temperature!!January 26, 2008 at 4:10 pm #196303fredferkel
Just wanted to add that I had a fault with my APP6403 freezer with the buzzer going off and no compressor kicking in.
I bought the PCB from UK Whitegoods, it cost half the price of the part from anywhere else and arrived in 36 hours.
I fitted it following the instructions above and it works perfectly. I even emailed a pic of the old board to UK Whitegoods as it looked different to the one in the picture on their site and they confimed that the new one did look different, but it was the correct part to order.
Brillian site, excellent advice and really helpful. If like me you are a keen amateur and stumbled across the site while looking for a repair man to call I would thoroughly recommend that you have a go yourself and save youself a lot of cash doing it yourself.
Thanks to all on the site. 🙂
April 21, 2008 at 5:00 pm #196304garethwear
I have a similar problem with the same model. The freezer works, gets cold and switches off the freezer. However when it starts to warm up every couple of days or so it fails to start the freezer and the first we know is the alarm going. If you bang the panel the freezer starts up again. Is this the PCB or is it something else.
Any help would be very appreciated.
Gareth
April 21, 2008 at 5:37 pm #196305admin
KeymasterRe: Schreiber APP 6403 Failure
Most likely the pcb with a stuck relay.
Bryan
August 2, 2008 at 1:59 pm #196306bigyin
Would it be possible to repair the old pcb… eg replace the relay
October 1, 2013 at 3:25 pm #196307wilbo67
I have the app 6403 integrated freezer which started clicking then following a power cut for approx 1 hour it started clicking more and everything defrosted . Since that I turned it off emptied it and restarted it , it is still clicking and not freezing.any advice would be good thanks
