Schreiber APP 6403 Fault diagnosis HELP REQUIRED
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Schreiber APP 6403 Fault diagnosis HELP REQUIRED
  • #65131
    Carls_quest
    Hi there,
    Has a SCHREIBER APP 6403 integrated freezer.
    Last night there was a smell like nail varnish (Acetone) coming from the freezer.
    The control lights started flickering.
    Now we have a slight flicker from the control panel and NO COOLING.
    Any suggestions would be appreciated.
    #359230
    Sounds like something has burnt out, without some investigation it is nigh on impossible to guess at what.
    There’s nothing in it that would give off a smell without burning out, basically a dead short other than what you put in it.
    HTH
    SAMURI
    Re: Schreiber APP 6403 Fault diagnosis HELP REQUIRED
    The electronic control module will have burnt out.
    It is sometimes due to condensation in the control box or water has been spilt on the kitchen worktop and run into the control box.
    This needs to be inspected to find out the cause before a new control module is fitted.
    Bob
