I need to replace the door seal on my internal MFI fridge (Schreiber APP6302). Before I buy the seal though I need to know how to get the old one out, as I’m a bit worried that it may be moulded in – the seal appears to just pull off but it actually goes in behind the inner lining. I’m not sure how to get this off.
If you peel the seal back so that you can see the plastic door inner behind, do you see screws evenly placed around its perimeter?
If so, seal is replaceable but you will have to detach the door inner from the main door with those screws. I would take the door off to do that job 🙂
