Schreiber Freezer APP6403
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Schreiber Freezer APP6403
  • #39985
    GMJC
    I have a problem with my Schrieber integrated freezer APP6403.serial No 20042710808-036103009-03
    It has stopped freezing.
    I have turned the temp switch to max, And the red warning light flashes on/off and the buzzer sound is on.
    I have pressed the fast freeze button, the amber led comes on, red led flashes on/off
    I have looked at other postings, which suggest that the PCB has a problem with the relay,
    I changed the 24volt relay on the PCB, to a 12v relay, but it has made no difference, and there is still no sound from the compressor.
    any help please.
    #264365
    expertcat
    Is the fan at the front running if no its a new pcb
    #264366
    GMJC
    Re: Schreiber Freezer APP6403
    Thanks for your reply,
    the fan is not working, as you say it must is the PCB,
    do you know the replacement part Number and where I can get a replacement from.
    #264367
    Replacement PCB from this link
    HTH
    GMJC
    thanks for your info,
    purchased new PCB, the fan is now workiing, put the fast freeze on for 2 hours, but no sign of freezer working, does this mean that the compressor is faulty? how can I test it. or is there some other problem?
