Schreiber lower left door hinge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Schreiber lower left door hinge
  • #16470
    steve_gill
    hi,
    I have a Schreiber “2001051 7143” built in fridge (under worktops) with a “cupboard door” front.
    the bottom hinge (hinges on the left-hand side) has sheared.
    In UKWhiteGoods shop, product number 246009700 looks like what I need (but is the top hinge). Is product number 246009800 the hinge I need?
    Can anyone advise?
    thanks
    steve
    #169944
    Dave_Conway
    Re: Schreiber lower left door hinge
    Hi Steve,
    Those models aren’t correct I’m afraid but the hinges mentioned will almost without doubt be the ones you need.
    246009800 is top right or lower left and 246009700 the opposite corners so you need 246009800 🙂
    Both taken as you look at the appliance from the front
    #169945
    Kurl
    I have this problem with my Schreiber fridge too and continue the search for a source of the said hinge. Although it may be different, I think mine is APP6302/20024514506/APM6321 !
    Please inform if you have any success
    Kurl
    #169946
    Dave_Conway
    Either APP6302 or APM6321 take the same hinges as steve_gill enquired about in the first post.
    To double check, remove the salad bin and the correct model will be on the rating label next to it 🙂
    You can see them both from this link:
    http://shop.ukwhitegoods.co.uk/hingekit … -hinge-kit
    Hope this helps.
