Schriber APP 6403 only works on super freeze
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Schriber APP 6403 only works on super freeze
  • #34816
    MrJ
    I have a problem with this freezer. It will not work unless I keep it on superfreeze. The alarm is sounds after 3 hours when it comes of superfreeze. I defrosted the unit yesterday and thought it wssn’t going to start up but after about an hour on superfreeze I could here the motor start. I have now switched off the superfereeze and it is giving the warning sound.
    1 thing to note, when I open the door to inspect the inside, when i close it I hear a hissing sound and the door seal seems to be sucking closed (It takes some force to open the door when it hisses)
    Any help is much appreciated.
    #244103
    Dales-Electronic
    Re: Schriber APP 6403 only works on super freeze
    What we need to establish is – is the motor running on fastfreeze and is the temperature going down to about minus 18C over the 3 hour period. Once I have this info I can give you a more exact response.
    #244104
    MrJ
    The motor is running on fast freeze and the temperature is dropping (to what I do not know).
    I just checked the freezer and the temp warning was flashing and it seemed to have defrosted slightly. I opened the doore and moved the themostat dial and it kicked into life.
    Ali
    #244105
    MrJ
    I have bought a new machine today. Ex display at B & Q for £140.
    You can consider this thread closed.
    Thanks for looking.
