SCHRIEBER APP6403
  • #40340
    GMJC
    problem with my Schrieber integrated freezer (APP6403, s/n 20031922281-036103009-03).
    I have replaced the PCB as recommended (thanks for information) the fan now works, but still no freezing,
    any ideas, could it be the compressor, if so how can I test it.?
    #265833
    cockney steve
    Re: SCHRIEBER APP6403
    I’d suspect that you need to do a continuity -check on the compressor which will probably entail removing the appliance from the housing. It could also be a faulty thermostat or sensor.
    you’ll need to patiently work through the circuit with a multi-meter. do NOT test live-plug out, Ohms measurements are all you should need.
    otherwise, time for “find an engineer” V (see below )
    #265834
    GMJC
    Thanks for your help, but I do not have a circuit diagram 😥
    #265835
    cockney steve
    That’s why I said you need patience!…..an understanding of basic electrical theory and circuits is also needed…..If you think this is beyond your capabilities, I’d suggest you use the “find an engineer” function under this post.
    ( the engineers on this forum, don’t usually get circuit-diagrams and in any case they are not allowed to release them, due to copyright and safety rules)
    having said that, if you can read and understand a diagram on paper, you should be able to trace it out in” 3D ” (the actual , real-life bits! ) 😆
