seal on freezer part of zanussi fridge/freezer..
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum seal on freezer part of zanussi fridge/freezer..
  • #19521
    borderfox100
    I will come back this evening and post the model no. when I get home from work but in the meantime, I was wondering whether its possible to replace the seal on the freezer part of a zanussi fridge freezer.
    The door closes but theres very little if any hold between door and fridge frame. I’d imagine its as a result of this that the freezers producing excess ice – and the motor seems to be running more than it should be (in my unqualified opinion).
    IF this was the case and I could order up a seal, is it straightforward to install/attach it to the fridge?
    #183485
    Dave_Conway
    Re: seal on freezer part of zanussi fridge/freezer..
    borderfox100 wrote:in the meantime, I was wondering whether its possible to replace the seal on the freezer part of a zanussi fridge freezer.
    That will dependon the model number 😉
    Many are moulded to the door in the factory so they can’t be removed, a new door is the only solution in most cases 🙁
    #183486
    borderfox100
    Finally managed to get around to getting back here with the relevant info;
    Zanussi Fridge/Freezer
    Model:Z 56/3 SI
    Product No. 925 881 658
    Serial: 13000088
    Fingers/Legs, etc crossed that its just a seal and not a new door!
    #183487
    Dave_Conway
    The seal is shown as a seperate part but please check that it can be replaced as often they are shown to be available but in practice are moulded as above.
    The seal is £44.22 and the whole door £106.38 😯
    An email to spares@ukwhitegoods.co.uk please if either are required 😀
    #183488
    borderfox100
    Thanks for that Dave. Jeez, these whitegoods parts are bloody expensive 😮
    I’ll have to persevere for a while as funds are tight following house move – but no doubt when the times right(or if the zanussi gets worse!), I’ll be back to order up.
    #183489
    borderfox100
    Turned out that the door was slightly out of line ie. it needed to be tightened up – which I never noticed!
    No new door needed thank god!
