Sealed drums recovery
Home Forums Appliance Recycling & Reconditioning Sealed drums recovery
Viewing 4 posts - 16 through 19 (of 19 total)
  • #343449
    bruce118
    Re: Sealed drums recovery
    Has anyone noticed the 6kg and 7kg drum is the same part no?
    ie a WF540 and a WT540 have the same drum F is a 6kg and T is 7 kg
    #343450
    That is only for the welded drum, the screwed drums have different part numbers for 6 & 7 kg drums.
    #343451
    gandh1
    iadom wrote:the WT761 on all of the sources I have access to is listed as 3 phase/welded drum only.
    There are a few versions of the WT741, some with sealed drums, some with split drums, some with 3 phase motors, some not.
    What he/you have is a WT741,
    is it not entirely feasible its a graded h/p rebuild ?
    #343452
    If it was then the rating plate would reflect that.
