Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Sebo Dart 1-ET1 Vacuum Not Working/Switch Assembly etc
- This topic has 11 replies, 3 voices, and was last updated 1 year, 7 months ago by
jontymox.
August 28, 2024 at 4:55 pm #102935
jontymox
ParticipantGood evening everyone,
I’m wondering if somebody can enlighten me with a problem on the above Sebo upright vacuum cleaner?
Essentially, my customer has dropped off the machine, reporting a “not working” fault, prior to disappearing on holiday at the end of last week!
My customer also confirmed that they had “taken a look themselves,” and removed the switch assembly etc from the handle unit,” leaving it with me to deal with.
I’ve now had a chance to take a look at the above, and the fault appears to be in a broken wire from the flex to handle assembly.
The flex is a two core cable, with what appears to be a rectifier or diode? wire from the on/off switch (live) into the handle loom.
I’ve established that this is the cause of the fault, as when twisting the above wire, the machine powered up.
However, I’m not sure what the above does, and if I can repair it, as it has a well crimped/soldered/heat shrunk joint, or whether it requires further parts…
Could someone advise?
Many thanks,jonty
August 28, 2024 at 5:43 pm #491130electrofix
Moderatorcant remember the dart not seen many of them
the sebo X4 has a 2 core input cable but has a heat shrinked component that touches the metal handle. I assume for static build up or the like
can you post some pics of the switch etc
August 28, 2024 at 6:26 pm #491131jontymox
ParticipantThank you once again for your help!
I can post some photos of the switch etc, with some difficulty…
You are quite right – the component you mentioned touches the metal handle, and may well be for static build up.
Anyway, the vacuum does power up when twisting the above (broken wire) and I’m trying to ascertain what I need to do to resolve, as I’m not a Sebo/vacuum specialist… perhaps I should try and repair said wire, if possible?
Thanks again,jonty
August 28, 2024 at 7:38 pm #491132electrofix
Moderatorcan easily get pics of the X4 handle but not sure if it will help, got 3 or 4 round the shop
ps they are really good tough well build vacuum cleaners. I have 2 X4’s at home
August 28, 2024 at 7:46 pm #491133electrofix
this is the x4 handle for referencehttps://www.youtube.com/watch?v=oujUs_Fw2_U
this is the Sebo felix which is very similar
https://www.youtube.com/watch?v=BZV4kMuK8X8
DaveAugust 29, 2024 at 3:58 pm #491134jontymox
ParticipantThanks again Dave,
Having taken another look at the above Sebo vacuum, I managed to get it to run very briefly by “twisting the flex” where it enters the handle.
However, I noticed sparking from the above area internally, and quickly disconnected the plug.
Having electrically tested the rocker on/off switch, it is faulty… so I bypassed it ( flex live and neutral to harness into handle live and neutral) and the machine didn’t power up.
I remain perplexed as to the purpose of the rectifier/diode, (or whatever it is!) which is joined to the live wire terminal (to on/ff switch) which then enters the handle…
The above part is broken, so I wonder if it needs to be replaced in order for the machine to work?
jontyAugust 29, 2024 at 7:03 pm #491135electrofix
Moderatorno that doide part as you put it is not needed to make it go
its probably a very high ohm resistor so expect 10 megs or so
could be just a faulty switch although flex breaks are the most common
August 29, 2024 at 7:13 pm #491136jontymox
Yes, it could purely be the faulty on/off switch, although the vacuum did not power up when I bypassed the switch…
jontyAugust 29, 2024 at 7:15 pm #491137jontymox
ParticipantAnd I’m not entirely sure where the sparking was coming from before… probably the switch, which is definitely faulty, so why didn’t it run when bypassed…
August 29, 2024 at 7:34 pm #491138electrofix
Moderatorwell all you can do is strip out the motor and check continuity
August 31, 2024 at 1:06 pm #491139keithos
ParticipantJust change the cable problem solved
August 31, 2024 at 1:14 pm #491140electrofix
Moderatorthought it might be
very common problem but a lovely easy fix
