Sebo K1 Komfort
  • #38082
    radiomike
    Hi there. We have a Sebo K1 Komfort which is completely dead.
    I suspect the switch or the cable reel. The fuse in the plug is fine.
    There’s no obvious way of getting it open, though. Where are the hidden screws?
    Any help most gratefully received.
    Thanks.
    #257657
    Goatboy
    Re: Sebo K1 Komfort
    radiomike wrote:There’s no obvious way of getting it open, though.
    Indeed, just to give your local Miele engineer something to do 😉
    I haven’t seen that particular machine, but the screws are usually under buttons, behind filter covers, inside the bag housing, or even under feet/wheels.
    It’s not a good idea to start snap bits off your vac tho! And of course, unplug the machine first! :zap:
    HTH
    #257658
    SWERV
    Re: Sebo K1 Komfort
    The fabric cushion around the machine has to come off, a bit fiddley. Remove the screws, IIRC they should all be apparent, not hidden. My guess is the cable, but it will come as cord rewind assy.
    POWER OFF 1st.
    Merv
    #257659
    radiomike
    Re: Sebo K1 Komfort
    Thanks guys. It was the cord – pulled taut once too often as we went around the house.
    The rewind assembly is now knackered – but the hoover works again, so saved £150.
    Thanks for the advice, M.
