Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Second hand oven, earth in the cable is black – confused !?!
- This topic has 4 replies, 4 voices, and was last updated 18 years, 4 months ago by
onuo.
November 15, 2007 at 3:18 pm #32223
onuo
ParticipantJust bought a second hand oven (Neff U1721) off a bloke, yes it does sound a bit dodgy…
Anyway i was told was the display one from a shop as its not been used however went to fit and the earth in the 3-core looks like its black, not copper.
Does not conduct an earth from the any of the surfaces or the earthing points – im confused!
Also with this being second hand/ shop display and a bit bashed about what safety check should i do before using.
November 15, 2007 at 7:36 pm #234128superfix
ParticipantRe: Second hand oven, earth in the cable is black – confused
They don’t come with a lead fitted.
It will need new cable, size will depend on KW rating of appliance.
Will need to be meggered and have earth checked.
I would urge you to contact a professional , as you have no idea what has been done to it, if it has been on display elements may have been disconnected and will obviously require re-connecting.
November 26, 2007 at 3:06 pm #234129Dal5band
What’s black ? — the plastic cover of the individual wire or the metal wire itself. It’s probably dirt or paint on it. If it’s the wire try scratching it.
The wire may be copper or may be “tinned copper” i.e silver coloured.November 29, 2007 at 9:05 am #234130swoop
You may have a copper conductor which may be badly oxidised!
Try scraping the conductor to see if the black can be removed
Oxidised cables rarely conduct so clean the cable back to bare copper (or silver if tinned) and recheck for earth continuity.
If you still cannot get continuity, Call a professional !!!!
Don’t mess with it as an earth fault CAN KILL !!!!!!
Follow this golden rule !!“If In Doubt – DON’T”
Dave..
January 2, 2008 at 4:49 pm #234131onuo
Hi guys,
Thanks for the replies and sorry for me being so slow to return, both me and my gf lost our jobs recently so everything has went on hold…The cable was indeed oxidized, I removed the fitted cable and fitted an appropriate to test. Although not a white goods engineer I do work as an engineer in broadcast television and my father was also an engineer in comms and electrics so have a good basis and thankfully not a complete idiot, well almost.
Upon opening I found that the connections had indeed been disabled, thankfully whoever had disconnected these had been good enough to mark the colours on the cabinet at the appropriate places and had left a handwritten wiring diagram and placement, obviously someone switched on.
Using a multimeter I then proceed to do an earth continuity on the front metal cabinet and switching – all good, checked that all other connections were also good and no crossover.
Ducked and cover – then switched on, and it all so far seems to work. All lights coming on, temp lights on, display on, switches operating as they should and fans spinning on. Haven’t let it come up to temp yet as it is still to be fitted into cab.
Certainly if it wasn’t for the lack of money I wouldn’t be buying like this, but completely broke and jobless at the mo so needs must.
Hopefully will fit later this week and hopefully the only problem is that of a cosmetic nature, the control panel and switches have got a fair few scratches on them as does the door panel, I’m not so bothered about the door (only if it was a cheap replacement) however the control panel and switches are pretty bad and would prefer to replace could anyone point me in the right direction to get these and at the right price.
Also in the terms of safety I will still have a pact test completed on this what does it cover, anymore than what I have already done ?
Cheers (again)
Al. -
