second LED from left flashing Hotpoint IDI60
Home Forums Public Support Forums Help And Support Dishwasher Help Forum second LED from left flashing Hotpoint IDI60
  • #18498
    soooz
    CAN anyone tell me what i need to do to sort this one out, I am presuming there is a blockage somewhere but maybe mistaken , if so how do i clear it?
    Cheers
    Sue
    #179227
    Re: second LED from left flashing Hotpoint IDI60
    Hi Sue,
    2nd led suggests a fill valve fault. Has the tap been turned off for some reason, is the fill hose kinked, is water coming out of the fill hose? As this is an integrated machine you may need to pull it out to check fully. Could be a faulty fill valve but the only way to test that is with the proper electrical test equipment. The electronics on these Indesit machines are known to be a bit unreliable.
    Please remove the mains plug if you intend to proceed further.
    soooz
    Thanks i’ll have a look and get back to you if the problem persists
    Really appreciate your help.
    Sue
